z bar problems!!!!!!
Car: 91 rs/94z 28
Engine: 305tbi/350LT1
Transmission: 5spd/A4
sorry for this being so long
ok... I put a T5 in my 91 rs a while back... swappd it out from automatic to stick..... i got pretty much everything finished, but i have to hook up my clutch linkage. At the time of purchase all i could find was the old mechanical style setup so i have the Z bar. ive got the one side mounted to the frame but i need the peice that screws into the block... it goes right above the oil junk... I dont know what its calld but its got a ball on one end and it adjust to take out slack in the z bar. I need one of those lil things bad so if any of you know where i could find one ill be very very grateful...
Car: 4
Engine: 6
Transmission: 5
It's called a ball stud. You get it at the dealer. It's about $5. It doesn't adjust, it just sits there. You need an adjustment rod to adjust it, which goes between the "Z bar" (its real name is bell crank) to the clutch fork. You can get that at the dealer, or Dorman used to service it, which you can get at lots of parts stores.
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
