Making 88 style 9 bolt backing plates fit a moser Ford 9"
Old Aug 29, 2002 | 11:03 AM
JohnnyIroc's Avatar
Car: 85 TA
A few people have told me that I would need to use the 10 bolt backing plates to get everything to fit.I know this guy steve in brooklyn that has used his 9 bolt backing plates on a moser 12 bolt but his backing plates are 89 style and have the larger 11.65 rear disc, which also has the aluminum caliper which i dont want to use. So what should i do about this, just bring the rear and my backing plated to a machine shop and have them make it fit? any help would be greatly appreciated. thanks
Old Sep 1, 2002 | 08:46 PM
JohnnyIroc's Avatar
Car: 85 TA
ttt
Old Sep 2, 2002 | 10:31 AM
Dr. Pepper's Avatar
You are supposed to use 9 bolt backing plates instead of 10 bolt. As far as the 88 versus 89 backing plates I don't see where it makes a difference as far as the axle is concerned. You are going to bore out the back side of the plate to leave room for the bearing extending from the housing. I don't remember the dimensions off hand but Moser can tell you their recommendations. Last time I did that I just measured the bearing and bored accordingly. Those were '88 9 bolt backing plates too by the way. You will also have to drill the backing plate for the Ford housing end retainer bolts. You could probably did up a little on the subject by searching.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
