recommendations - replacing rear
Old Aug 30, 2002 | 04:14 AM
logikal6785's Avatar
this summer after spinning twice at 85 my car slammed parallel into a curb at 55mph and jumped 1/2 way over it, slowing down over the course of 100 yards. It did all this while traveling backwards while still in gear. 2nd gear to be exact. as i limped it home it whined a lot in the back and when i turned the corner to climb our hill i thought the back right was going to quit turning altogether =/
anyway i miss my car a lot, but i'm rebuilding it next year and a new rear is one of the things i'm putting in
the specs on my GTA v2 are :
LT4 engine making ~429hp/400tq
on a T-56 with 3" aluminum driveshaft
direct port spraying 125-150 shot of N20.
I'd really like grabby discs on the rear so should i be looking for a rear off an LT1/LS1 firebird or camaro ?
(i had 3.73's w/posi in my GTA and they were great, if i could get 3.73's posi'd behind my car again i'd be stoked )
thx again for all the help you guys can give me
Old Aug 30, 2002 | 05:14 PM
come on ...
Old Aug 30, 2002 | 05:50 PM
Gta-Paladin's Avatar
Grab a moser 12 bolt or a Moser 9"
I'm going with a moser 9" for my tt 377
Old Aug 30, 2002 | 08:16 PM
are you getting p/n BP9HP2 ? @ $920 for a complete rear (minus brakes) that looks awesome, and i know that moser makes quality products so no worries about stripping the gears
do you know which rear it's based on, the thirdgen or the 4thgen ? i have to start looking at brake solutions, and i also have to decide which rims i want before i pick rims - 97 WS6 rims for a 4thgen rear or repro. firehawk rims for a thirdgen
Old Aug 30, 2002 | 08:51 PM
yeah thats what im hitting up im quite excited
the 9" is a ford nine inch its not based on a fourthgen rear
Old Aug 30, 2002 | 09:26 PM
storman's Avatar
moser 12 bolt for f-body
im using the moser 12 bolt dedicated to the f body. torque arm mount etc. it installed very easy just asemble the brakes of your choice an axles. i went top line on gears axles 4 piston discs and narowed 3/4 inch on each side at no charge. it was like $2700 but worth it an it will never break!. if you instal the ssm lift bar kit at same time you dont have to run a torque bar any more. stay all chevy dude
Old Aug 30, 2002 | 09:58 PM
what i meant by 4th gen rear was the bolt pattern on the ends ... how did you order yours?
Old Aug 31, 2002 | 09:01 AM
storman's Avatar
moser 12 bolt
i orfered mine to fit my aftermarket rims an for the willwoood disc kit an e brake. they will set up any combination you want.
Old Aug 31, 2002 | 07:53 PM
sweet. thx for your help guys =D
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
