Gear change 2.73 to 3.42
Old Aug 30, 2002 | 11:41 AM
mat89RS's Avatar
I'll be swaping the gears this weekend , 3.42 are from a 92 camaro.
Will It fit without problems ?
What oil do I use ???
I bought a gasket and a pinion seal, do I need anything else ?
Old Aug 30, 2002 | 12:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those gears won't work on your carrier. You'll need a 3-series carrier, like maybe the one the gears came from.
You can probably get away with the shims that are there, if you're real careful. If I was you I'd buy a complete kit, like the Ratech 308K maybe, because you're going to need some bearings for sure, and it's cheaper to buy the kit than the bearings by themselves, and in thelit you get a cruch sleeve, shims, seal, etc. too.
Old Aug 30, 2002 | 12:25 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Besides a ring & pinion,
2.5qts gear oil
posi additive (if you have a posi)
Crush collar
pinion nut
dial indicator to set pinion depth
assorted shims, pinion & side carrier
gear marking compound
side bearings
pinion bearings
(all of the above bearings will most likely worn or distorted when pressed off your old parts)
access to press for bearings
a good service manual
time & patience
Old Aug 30, 2002 | 04:29 PM
mat89RS's Avatar
RB83L69
Explain please !
What is it that doesn't fit from a carier 2 to a 3 ?
Old Aug 30, 2002 | 05:00 PM
ronterry's Avatar
Car: '94 Corvette
I'm looking forward to doing mine this weekend also. I'm going from a 2.93 to a Richmond 3.42.
I ordered the 2 Series 3.42 gear, so there must be a difference in size if there's a different part number between the 2 & 3 series 3.42.
I'm about to head out and pick up some axle tube bearings, oil, and other goodies.
BTW: I also ordered the installation kit, and in the photo below you can clearly see there's some parts involved. I guess you can reuse everything, but me I want this rear end to last - that & it's for racing
Ron
Old Sep 1, 2002 | 06:30 PM
Ricktpi's Avatar
It's the thickness of the ring gear. The 3 series carriers are offset more to allow for a larger pinion gear.
Old Sep 2, 2002 | 07:21 AM
mat89RS's Avatar
How much is a kit like the one in the picture above ? does it comes with shimes that would work ?
Is there a shimes kit ?
draco
Oct 4, 2015 09:25 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
jbd1969
Aug 17, 2015 07:06 PM
novaderrik
Aug 10, 2015 12:44 PM
