anybody ever get a flywheel, at autozone......
Old Aug 31, 2002 | 08:31 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
or any other similar store, i have access to napa,autozone, orielly's, advance auto, and carquest, and of course a local gm dealer(whom i'd rather not visit)
i'm talking about a flywheel for my 84 lg4 car, that i am putting a t5 in.
after several used ones, have been found and arrangements have fallen through for whatever reason, i have decided to just get a new one
i also have an LMC truck catalog sitting here, it has a flywheel listed that i think would work, its just gotta be for an internal balance small block, pre 1985, 153 tooth right?
Old Aug 31, 2002 | 09:00 AM
Nordbert's Avatar
That flywheel will work if you have the two piece rear main
seal. BTW, how much are they asking for it?
Old Aug 31, 2002 | 09:11 AM
Car: 1984 Firebird
Axle/Gears: 4.10
I believe it was $130, i will check tonite, after work the magazine is at my dads house right now, I'll post back here if its any different
i also just checked gmpartsdirect, and they want like $145+ like $28 to ship the damn thing, and that is a lightweight one only15 lbs.
Old Aug 31, 2002 | 11:19 AM
84TAProject's Avatar
130? I dont know about sticks much so forgive me. I needed a flywheel for my 700R4 and new at advance auto it cost like $35. That seems high, but for a stick it might be different. You need a flywheel for a swap, you dont know fear until you shatter your flywheel and it sounds like a spun bearing.
Old Aug 31, 2002 | 06:13 PM
Car: 1984 Firebird
Axle/Gears: 4.10
for the guy asking about the lmc catalog, i must have been looking at something else cuz i could npt find it in that book
Old Aug 31, 2002 | 06:27 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
wow, ONLY $130 for a manual flywheel
i've gotten quotes from the GM parts departmartment at work, (and i even get a GM employee discount) and the cheapest brand new flywheel they could me was about $250
so if you can get a lite-weight for $130.......jump on it!
oh yeah, manual flywheels cost alot more than auto's cuz the auto is skinny as hell, whereas the manual is about thicker with more area to allow the clutch to grab, as so you can cut them to remove the glaze when changing the clutch
hope i helped
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
