700R4 Needs Computer?
Old Sep 1, 2002 | 09:40 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
My car has all sensors and the computer removed. I was considering converting my T5 to a 700R4 as I build my motor. Can I use a 700R4 without a computer or does it need the computer to control the shifts?
Old Sep 1, 2002 | 09:53 PM
82camaro's Avatar
Car: 82 camaro SC
Computer not needed, the 700r4 isn't computer controlled. You will need some way to lock/unlock the torque converter. Not a problem though, do some searches on the subject, TCI, B&M, and Painless wiring offer a conversion kit or you can make a manual switch.
Old Sep 2, 2002 | 11:47 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thers another option for a functional lockup converter found on early S10's. The S10's used a 2 wire vacuum switch connected to manifold vacuum one hot wire ran from the switch on the brake "brake switch must be 12 ign power" to the vacuum switch then ran down to the "A" termial on the transmission, the other wire on the vacuum switch goes to ground. The part cab be purchased at either a local parts store or the dealer from $10-18.
The switch will lock the converter @ 8in of vacuum+ I just dont have the part number handy.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
