37 & 9, 7.5" ring & pinion
Old Sep 8, 2002 | 09:46 AM
five3s&a4's Avatar
Car: 1984 Berlinetta T-Top
Engine: 355/435 hp
Transmission: 350 turbo
Axle/Gears: 10 bolt/drum-4.10
does the 37ring and 9 pinion from a s10 4x4 work in our 10 bolt rear ends??
Old Sep 8, 2002 | 09:53 AM
Jay 727's Avatar
It should work, 4.11's.
Old Sep 8, 2002 | 09:58 AM
five3s&a4's Avatar
Engine: 355/435 hp
thanks on 4.11
Jay, I am assuming with less teeth they will be stronger(bigger teeth)
Old Sep 8, 2002 | 10:06 AM
DragracerArt's Avatar
Car: 1970 Tube chassis Camaro
Engine: 632 Big Chief
Transmission: Rossler TH400
I just installed exactly this setup in my '85 Z28 5-speed car...
Got a 37/9 gearset and posi unit from an S10 4x4 in a junkyard for $35...
If you use the S10 carrier, just make sure it's got the same axle splnes as your Camaro (26 or 28)
Old Sep 8, 2002 | 11:48 AM
Jay 727's Avatar
Re: thanks on 4.11
They will actually be weaker but thats the only way to get the 4.11 ratio and still have the gears fit into the case.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
gord327
Sep 29, 2015 10:18 PM
