Can I use Dextron III?
Tranny dipstick on my 2.8 says, "Use Dextron II ONLY". I have 3 bottles of Dextron III sitting on my shelf in the garage. Is it safe to use? I would think so, but then again, I don't want to blow anything up. I just need to add a little until I have time to change the fluid and replace the gasket on my pan. Thanks!
Its reccomended that you use Dexron III. When your dipstick was made, Dexron II was "the thing" to use. Since then, Dexron III has superceded Dexron II. I really don't think you can even buy Dexron II anymore.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Look at your dipstick again. There's no T in Dexron. I think there might be a Dexron IV now.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Also, LOOK at the bottle of Dexron III and it should state that it replaces/will work in place of Dexron II....
Every bottle of Dexron III that I have seen states this...
HTH,
HTH,
New2Chevy
Oct 4, 2015 11:27 PM
I think it sounds cooler with the "t". At least I didn't say camEro! :lala:
