Opinions needed, I think my trannys dead:(
Old Sep 17, 2002 | 10:37 AM
blk86ta's Avatar
Its a 700r4 and heres the low down. before it wouldn't even hold first gear, everytime I took my foot off the gas it would hit nuetral. I adjusted the shift linkage to the best of my ability(better directions would make it a lot easier) and now it will hold first throughout the rpm band but it still won't upshift in drive. it just shifts from 1st to neutral.
I thought my clutched burned out or something so I took off the drain pan. there wasn't any debris though so I don't know if its just an adjustment issue or what. HELP!
~thanks
Old Sep 17, 2002 | 03:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is the pan still off? Cut open your old filter; use angle cutters to separate the metal side from the plastic side. Unfold the filter paper.. look for big piles of metal...
How did the fluid look/feel/smell? Brown/gritty/cooked? Or red/slippery/like oil?
Old Sep 17, 2002 | 05:09 PM
Kennyz's Avatar
You did have tranny fluid in it? If you are low the tranny will not shift or not shift right. Driving it like that can burn up the clutches
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
