Soft Shifts
Old Sep 17, 2002 | 10:42 PM
naachoo's Avatar
Soft Shifts
well i got a transgo shift kit and it seems to shift softer now,
this is what the box says.
SK 700 Junior
System Correction
Correct: sticking tv & clutch failure
now i know it is in right, because a buddie at Chevy put it in for me and we did it all by the book, there were no problems before we did this project. now my question is... is this a performance kit or did i recive the wrong one? cuz now it seems to slide into 2nd gear and not a swift shift. it also shifted harder when stock. evey thing was put in clean and its all tight. if it is the wrong kit
what do i need to get to make those shifts harder without spending a ton of money?
92camaro rs w/305 700r4
78,000miles
Old Sep 18, 2002 | 01:53 AM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
mY TRANS-GO KIT IS # PSK 700. Did yours come with a new 2nd servo?? If not then I don't think it's the performance kit.
Old Sep 18, 2002 | 05:23 AM
Pro Built Automatics's Avatar
The Trans-Go Shift Kit (Junior) as is will not help you out performance wise. I can tell you how to modify this kit for HD applications, but I would add the Corvette servo and larger boost valves, along with the valve body modifications I suggest. You could try the modifications I suggest first, then add the boost vaves and Corvette servo later.
Old Sep 18, 2002 | 07:51 AM
naachoo's Avatar
yeah, what do you suggest to do? i am up for anything to help me now.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
