whining rear
Old Sep 22, 2002 | 11:53 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
whining rear
I'll do my best to explain the situation. The rear is from an 84.
The whining does'nt start until I am at slow cruising speed, say 35 MPH.
At that point, if I press the accelerator the slightest bit the whining stops. Also, if I let off the accelerator the whining stops.
It doesn't make any noise when I take off, slow or fast.
It sounds like it is coming from the passenger side and I am thinking it is the outer wheel bearing which isn't such a big deal. Or is it?
Are there any gear fluid additives available to quiet things down?
Thanks,
:hail:IROC-Z
Old Sep 23, 2002 | 01:14 PM
jonarotz's Avatar
Car: 91 Z28
As far as being a big deal, you will have to take the diff. cover off remove the cross pin and bolt, remove the c-clips and slide the axle out. You will need a slide hammer to remove the old bearing. Make sure it isn't any brake noise before tearing everything apart.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
chazman
Aug 22, 2015 02:01 PM
