Dana 44 experts! please enter
Old Sep 22, 2002 | 05:49 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
I am in the process of installing a Dana 44 in my car but I noticed that my u-joints are bigger in diameter. So my question is what do I use as in do I ask the parts guy for 92 Firehawk ones or am I goin have to change my driveshaft yoke? Um please help lol!
Old Sep 22, 2002 | 06:19 PM
ronterry's Avatar
Car: '94 Corvette
I'm assuming the regular Dana 44, & not the later 84-96 Manual Vette 44's...
This is right out of the Richmond Catalog for the Dana 44
Bronco & U100 (Front) 71-77
Ford F-100 (Front/Rear) 67-77
Ford F-150 (Front) 75-77
Ford F-250 (Front) 67-77
Chrysler W100 (Front) 69-98
Chrysler W200 (Front) 69-98
Chevrolet K-10 (Front) 67-79
Chevrolet K-20 (Front) 67-79
Blazer (Front) 75-79
Scout (Front/Rear) 67-80
AMC Jeep C101 (Rear) 67-72
AMC Jeep CJ5 (Front/Rear) 67-75
AMC Jeep CJ7 (Front/Rear) 67-75
AMC Jeep Wagoneer (Front/Rear) 67-83
Ford F-100 (Front) 78-97
Ford F-150 (Front) 78-97
Ford F-250 (Front) 78-97
Bronco (Front) 78-97
Corvette 80-82
Don't know about the over all size of the U-joints, but you could compare them at the parts store. Beyond that, go check in with your local drive staft or trannie shop, they might help.
Ron
Old Sep 22, 2002 | 06:44 PM
JERRYWHO's Avatar
The u-joint you need is a cross over type. The factory u-joint is a Rockwell type and the yoke on the dana 44 is a dana #1310 size.
The U-joint part number i use is made by Precision #355
I hope this helps
Jerry
Old Sep 22, 2002 | 06:59 PM
WECoyote's Avatar
1QWIKZ,
What you need is called a 'conversion' u-joint. If you are using the steel driveshaft then these are some choices:
NEAPCO 3-3130 (NEAPCO also has heavy duty line called Brute Force....I believe it is 3-3130BF....)
Precision 372
Dana 5-544
If you are using the aluminum driveshaft then:
Precision 369
Sorry, I dont have any other numbers for use with the aluminum driveshaft. This should at least get you started.
FYI.....the Precision 372 is about $32......at least that is what I paid at Bumper to Bumper. It fits the pinion yoke (Spicer) perfectly.
Hope this helps!
BTW..............where did you manage to find the elusive Dana 44?
Mike
Old Sep 22, 2002 | 07:15 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Thank you for the quick replies! I think this will have me all squared away I hope but if I have any questions I'll definitely will be asking you guys again........ Thanks guys!!!!!!!!
Oh yea, I actually scored the rear off of ebay about a year ago for 800 but my 10 bolt was still intact and I got it for a back up and ultimately I need to put it in now. lol
Hopefully it holds up better to the holeshots with NOS and slicks compared to the 10 bolt which actually lasted alot longer then I thought it would.
Old Sep 30, 2002 | 06:08 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Ok I have another question for you guys. Jerrywho already has answered quite a few of my questions but I have another one lol.
Jerry said that I could get brakes from a 89-92 and they would bolt right but I am having a problem finding them but there is a ton of 87-88 that I can get ahold of. So my question is will they work and what will I have to do to make them work thanks guys!
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
