th350 in 85 z
th350 in 85 z
I Have a 350turbo tranny w/6in tail shaft is it true that i can use a drive shaft out of a 82or83 camaro w200r4 if not what do i need to make it work thanks for any info you can give me
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Re: th350 in 85 z
You also need a new bracket for the tq. arm or if you have the SSM kit like me you don't need it.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
youl need ot find a 9" tail th350(trucks hve them) and find an aftermarket tailshaft hous9ing to bolt torque arm to
th350 and 2004r never came in these cars
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
82-83 f-body that came with the 3 speed auto were TH200c. The driveshaft length from them is close enough to use with a 6" tailshaft TH350.
The 9" long tailshaft TH350 is close enough in length to a 700R4 that those driveshafts are interchangable.
You will need a swap kit to do the conversion.
