Trans out...what is this thing?
Car: 88 GTA
Engine: 305 LB9
I am in the process of replacing the clutch in my GTA project car (first clutch job for me). I just pulled the tranny out and there is a tube (thin, white in a black casing) running from the top passenger side of the trans and at the point the trans bolts to the bellhousing it takes a 45 degree turn upwards. There appears to be some sort of cap at the end. It's definately more of a tube than a cable. What is this? Did I miss disconnecting it? What does it connect to (if anything)? I searched around above the bellhousing and can't see anything this tube would connect to. Thanks folks.
Kevin
Kevin
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
yup its the vent and the reason for being so hight is to avoid water getting into the transmission.
