sh!tty torque converter
Old Sep 27, 2002 | 04:58 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
i have an 89 formula 700r4 tranny. when driving around i can feel the torque converter locking and unlocking all the time, ihave changed the tcc switch and it still does it. if i wired the tcc switch to a switch inside the car so i can lock or unlock the torque canverter myself, would this work and when should i have it lockup and when should i unlock it?
Old Sep 28, 2002 | 05:33 PM
4L60bliss's Avatar
You could just have the Lock-up speeds increased in the PROM so that it won't engage driving around town (unless your speeding).
Stock setting has the TCC lock up around 38 MPH.
Old Sep 28, 2002 | 11:23 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
arap too? I haven't messed with that part of the chip yet and my converter locks at 28, right after third gear shifts. Could be the tv cable setting. I know how it's supposed to be set, but that doesn't always work. I just built a new tranny with the transgo 2/3 kit. If you have a modified throttle valve, the stock setting may NOT be right for you. Try pulling it out 1 click and see if it helps you.
Old Sep 29, 2002 | 01:32 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Ive been hearing and searching on this torque converter lockup switch, when should I have my switch engaged, like when im on the expressway cruising? Ive heard this is good for drag racing, i shift my car manually. Would this improve my et?
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
