pilot bearing or bushing?
Old Sep 28, 2002 | 07:52 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Which should I use? One of my buddies told me to use a bearing with the little rollers in it. Someone else told me not to use a roller bearing because it would break, and that I should get a brass bearing instead. Opinions?
Old Sep 28, 2002 | 08:47 PM
ede's Avatar
ede
i've used both in a lot of differant cars and trucks and can't really see a differance and have never had problems with either
Old Sep 29, 2002 | 04:10 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
There are quite a few testimonials of bearings blowing up over on CamaroZ28.com, so I went with a bushing.......
Old Sep 29, 2002 | 04:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bearings are the heavy-duty application. All trucks use bearings for example.
But like ede said, as long as it's not defective, it hardly matters. I prefer a bearing but either will work fine.
Old Sep 30, 2002 | 04:56 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I like the roller bearings, and have had a bunch of them.
Never had any trouble with them , but I always replace them when I do the clutch (inexpensive part, might as well replace it while it's apart).
-Rich-
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
