can some1 pls explain what tc lockup means
Old Sep 29, 2002 | 02:28 AM
Locry's Avatar
i have an 83 t/a which was gutted of all electronics... i don't know what locking up the tc is supposed to accomplish...
help, can some1 explain it to me...and what should i do to facilitate lockup... tnx
Old Sep 29, 2002 | 11:01 AM
Locry's Avatar
i guess i'm not the only one who doesn't know the answer... oh well
Old Sep 29, 2002 | 11:20 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The lockup is a function accoplished by a valve in the VB getting a charge from the ECM then sending extra fluid to the tq converter. This Fluid pushes the clutches "very similar to a standard transmission"
to a lock posistion eliminating slippage associated with early tq converters. Basicly it improves highway mileage by reducing engine RPM by 400-500 RPM and also reduces damaging heat due to converter slipage.
Old Sep 29, 2002 | 11:29 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Re: can some1 pls explain what tc lockup means
Torque Convertor lockup is pretty straight forward if you think about it. A torque convertor consists of three basic elements: the impeller, the turbine, and the stator.The impeller is joined to the convertor case, which in turn, is joined to the flexplate on the back of the engine(the crankshaft). The impeller creates fluid pressure inside the convertor.The impeller has little blades that direct the fluid away from it and toward the turbine, which is splined to the input shaft of your trans. When the impeller throws the fluid away from itself, it strikes the turbine and forces it to move. When the car is in gear this causes movement. As you can imagine, there is a great amount of slippage(heat) generated by this process. A lockup convertor has a clutch disk that is controlled by a solenoid that basically locks the halfs of the convertor together to eliminate this slippage. This is why, in an car with overdrive, after all shifts are made, 2 through 4, there is another slight rpm drop, usually 200-500 rpms, this is lockup. Less rpms mean less fuel usage and less pollution. Hope this helps.
Old Sep 29, 2002 | 11:30 AM
jpk91rs's Avatar
Yeah, that too.
Old Sep 30, 2002 | 02:17 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
tc lockup
Had tranny rebuilt, my transmission doesn't have the tc lockup valve in it, but alot of the time if i give it a little gas it shifts up to 3rd gear before i reach 20mph. Mechanic says it could be the computer. Adjusted the Throttle Valve Cable and it helps a little. Bad Computer? Does the computer control the Lockup?
Any suggestions??
Old Oct 4, 2002 | 03:49 AM
Locry's Avatar
thanks for the info guys,
when does it need to lock up? od?
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
