Where is the rear end code on my rearend?
Old Oct 2, 2002 | 10:44 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Where is the rear end code on my 83 Camaro's rear end? I'm thinking it's a 3.08 but wanting to make sure, Thanks for your help!
Old Oct 2, 2002 | 10:54 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
its on the front of the rear end, should be drivers side, on the tube (axle)
Old Oct 3, 2002 | 06:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The codes are a very poor way to "make sure"... take off the cover and look. Have you changed the fluid lately? Then the cover needs to come off anyway; just look at it while you're doing the scheduled maintenance.
Old Oct 3, 2002 | 08:03 AM
83 MidniteZ's Avatar
Mine was on the axle tube right next to the center section. It was on the passenger side though. I think it was on the passenger side for 83s. Get under there with some sand paper and a flashlight...good luck! Your best bet is to open it up like RB said. Fluid probably needs changing anyway
Old Oct 4, 2002 | 02:02 AM
ede's Avatar
ede
the code doesn't prove anything other than what the general built it with not what it has. if you want to be sure pull the cover ,lot easier too.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
