Tranny problem
Old Oct 7, 2002 | 01:58 PM
pabloz28's Avatar
Tranny problem
I was removing my transmittion last night and I ran into a problem. I couldn't get to the top 2 transmittion to engine bolts. Other than being double jointed, anybody have any tips, hints, or suggestions? Thanks.
Old Oct 7, 2002 | 02:15 PM
flyway190's Avatar
Try using a 9/16" distributor wrench or a flat ratcheting wrench.
Old Oct 7, 2002 | 02:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
not 9/16" on F body ??
Old Oct 7, 2002 | 03:12 PM
flyway190's Avatar
that would be interesting, wouldn't it?
Old Oct 7, 2002 | 04:56 PM
Recluse's Avatar
I just did that the other day. PULL THE DISTRIBUTOR. Youll thank me later. It seems to be the only way to get to the drivers side bolt. Use a long 9/16 boxend wrench from the top on both sides. you cant get to these from under the car. The problem is that the wiring harness goes back there and it has 2 metal straps around it with THOSE 2 BOLTS going through it holding it in place. Its a catch 22. you have to remove the wiring harness to get to the bolts but the bolts are holding the harness in place. It kinda sux. good luck!
Old Oct 7, 2002 | 05:55 PM
4L60bliss's Avatar
I use a 36" extension w/ a 14mm swivel socket and a 3/8" Impact and get all six from behind the tranny in about 30 seconds.
Old Oct 8, 2002 | 07:38 AM
pabloz28's Avatar
Thanks everyone. I'll try that tonight and see what happens
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:52 PM
