Quick TH350 Question
Old Oct 7, 2002 | 10:26 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I'm putting a 350 trans into my car, and the detent cable that it had on it was too long for where my bracket and carb are located. So I was wonding, I got the B&M universal 350 kickdown, and I noticed there's 3 stages in stiffness on the cable. Where do I want WOT to be? When you pull it it's very loose at the begining, then a little tougher for most of the way, then the last 1/4 in is very hard to pull and then it dosn't move at all. Do I want where it stops completely to be WOT, or right before where it gets hard to pull?? Thanks.
Old Oct 8, 2002 | 09:44 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
right before
Old Oct 8, 2002 | 12:50 PM
Stingraye's Avatar
Car: 1986 Trans Am
U positive?? Cuz I want to be. Anyone else?? Thx guys
Old Oct 8, 2002 | 01:17 PM
Pro Built Automatics's Avatar
You adjust this cable to get a 3-2 or 2-1 kickdown (down shift). If the engine has a lot of bottom end torque, then adjust it so it takes a lot of throttle to get it to kick down (down shift), and it is just the opposite for an engine with very little bottom end torque. After that fine tune it so it feels the way you like it to behave. If you do not have the Trans-Go Performance Shift kit?, I would install one.
Old Oct 8, 2002 | 07:16 PM
Stingraye's Avatar
Car: 1986 Trans Am
I have the transgo shiftkit, and have about 360 HP and 350 TQ. Just wanted to check where to set the cable too, wether WOT is at the full length of the cable, or right before where it gets hard to pull then stops. thx
Old Oct 8, 2002 | 09:07 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
rigfht before it stops.
Old Oct 8, 2002 | 09:09 PM
Stingraye's Avatar
Car: 1986 Trans Am
ok, so fast68, i do want the cable to pull through the tough spot for the last quarter inch or so and then have the throttle and cable stop at the same max point? Just makin sure I have this straight.
Old Oct 8, 2002 | 11:21 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
you just dont want cable to bottom out before throttle does, but close though,.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
