U joint's?
Old Oct 8, 2002 | 07:09 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
U joint's?
How do you remove, change U joint's? Is there anything special for our car when you do it?
Old Oct 8, 2002 | 08:39 PM
ronterry's Avatar
Car: '94 Corvette
I was able to complete this task solo with my shop press.
If your using a vice than I would recommand a friend to help.
I used a big socket, and a small one to push the U-Joint out. (Use your imagination on that one)
If it's still the original stock U-joint, then you'll need to apply a few more pounds of force to pop it out, cause theres a plasic retainer that's molded inside the driveshaft groove at the factory. You'll want to completly remove all the pieces of the retainer once the U-Joint is out.
Press the new one in is cake. The aftermarket one's are held in by C-type clips.
Good Luck, and don't freak out when that plastic retainer lets go. It spooked the **** out of me for the first time
Ron
Old Oct 8, 2002 | 09:35 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
.....Hmmmm, I am not sure I get it......
Old Oct 9, 2002 | 06:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Best thing to do might be to take it to a parts store, and watch them do it... then you'll know how to next time (and I guarantee there'll be a next time)... it's quite simple once you "get it", and quite dangerous to yourself and the parts and tools if you don't.
Old Oct 9, 2002 | 08:44 AM
ronterry's Avatar
Car: '94 Corvette
I think a trannie shop might be able to slap both in for $20 bucks or so.
A shop press is realy the only way, but I have done it on a vice which is a pain.
If you don't line the sockets up right you might bend the crap out of the end of the drive shaft, making the new ones imposible to install the C-Clips. So take care if you deside to tackle it yourself.
-and don't forget to give it a good shot of lithium grease (water proff) in the zerk fittings before you install.
Ron
Old Oct 9, 2002 | 10:26 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I just got done doing mine on my 86 i was unsure how to do it until a friend of mine told me about the nylon that holds it in there instead of the c-clips. take a blow torch n heat it up the nylon will melt and run right out. Makes things a little easier instead of beating the daylights out of the drive shaft.
Old Oct 10, 2002 | 02:18 AM
ronterry's Avatar
Car: '94 Corvette
The press takes little or no force, but the vice on the other hand - you'll need a pipe to give you leverage.
Ron
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
