what rpm do you guys run at the strip that use a TH350?
Old Oct 8, 2002 | 10:33 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
as i calculate it i will b around 5000RPM's if i get a TH350 with my 3.73 gears....
its really high and i dont wanna blow my motor
what do you guys run with your TH350's and different gear ratios?
Old Oct 8, 2002 | 10:41 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i've got 3.42 gears with a 2400 holeshot and i'm at about 4500 at the lights , shifting at 5600.
Old Oct 8, 2002 | 11:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If an engine can't rev to 5000 then there's something wrong with it. Just about any engine should have no problems reaching 5000 rpm and surviving. Getting closer to 6000 and you should have some better internal parts. 7000 and there's not much left that's from the factory.
The rpm range depends completely on the engine itself. Can choice, induction system, heads etc all determine the rpm range of the engine.
Gear ratio's again depend on the rpm range of the engine but also depend on the tire size. 3.73 gears are middle of the road for performance. An engine that revs higher would like 4.10's but would also need taller tires.
Old Oct 8, 2002 | 11:23 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
this should be an interesting thread.. heh
I dont see 5k rpm being good for an engine with like over 100k original miles on it though, heh
rod knock, cough cough&*
Old Oct 9, 2002 | 01:25 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Then get if off the track in into a motor shop gettin a new motor - 5000 is **** stock it shuold be good till 5500.
Old Oct 9, 2002 | 04:49 AM
EvilCartman's Avatar
Car: '82 Z28
I've run mine up to 6,000 and a couple times beyond by accident and the motor still runs just fine but then, it only has about 15k on it :lala: Normally shifted at 5,200 - 5,500. Can't wait to see what the single plane does for the top end I just bought for cheap.
Old Oct 9, 2002 | 06:25 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I had the 700r4 with Coan 2800 stall and 3.42 gear, consistent 1.95 60' times and 14.1 E.T.'s crossing finish line 4400 rpm.
Now with the TH350, 3500 stall, 3.42 gear(killing me) bigger carb also My short times are consistent 1.82 and E.T.'s are 13.6
I shift every gear out at 6000rpm and at the big end I only cross around 45-4600 rpm/ hence me wanting taller gear/tire combo.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
TreDeClaw
Aug 14, 2015 06:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
