quick trans question
Old Oct 9, 2002 | 11:12 PM
naachoo's Avatar
ok, we rebuilt my 700r4 and but a overhaul kit in and a corvette servo, now i noticed that when i but the car into 1st it will shift into 2nd eventho. it shows its in first. but if you slow down it will drop back into first. this never happened before.
anyone know whats wrong?
thanks
aaron
Old Oct 10, 2002 | 12:04 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
All AT trans have a pressure governer. This means that if you have the trans selected to 1'st gear, if you take the rpms so high that the trans hits maximum pressure, the governer will overide the manual selection and automatically shift to 2'nd (basically so you don't blow u'r trans to smitherines). At what RPM was it shifting to 2'nd gear at?? With that trans, with that servo it shouldn't go to 2'nd gear till about 7000-8000 RPMs (I would konw, had the same setup). If it shifts way sooner than that, then you probably have the shifter linkage off a lil that when the shifter is in first the trans is actually in 2'nd.
Old Oct 10, 2002 | 10:06 PM
naachoo's Avatar
well it will shift maybe at 3,500 or somthing like that, real ow tho. i know it is in frist before it shiftsjust from the sound. but that only happens when 1st is selected. but in drive the car wont shift till it red lines almost. which is normal. it makes the tires chirp but only shifts hard when flored,
but if your driving calmly you would never know anything was done to the trans. is that the was it should be with a corvette servo?
also where is this pressure coltrol at, so i can try it?
Old Oct 10, 2002 | 10:09 PM
naachoo's Avatar
also note that when i said it shifts to 2nd, around 15 to 20mph when you slow down it will downshift back to first, you know when that happens..
Old Oct 11, 2002 | 12:15 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
for real ?
Old Oct 11, 2002 | 07:01 PM
4L60bliss's Avatar
Yes, most 700's will override the manual first selection and force a 1-2 shift if the RPMs get too high. If that bothers you, you can install the TransGo reprogramming kit and kiss it goodbye.
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
