th-350 flexplate?
Old Oct 12, 2002 | 08:36 PM
pokes87iroc's Avatar
th-350 flexplate?
ok what im doing is putting my tpi 305 with a one piece rear main seal motor into a chevy truck. its a 79 with a th-350 tranny. the flexplates r not the same . do any of u know what flexplate i will need to olt a one piece rear main to a th-350? i one that is one the motor will not bolt up to the torque converter. there is about a 1/4 inch space between the flywheel and the torque. i need this information as soon as posable thanks guys.
Old Oct 12, 2002 | 11:07 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
that gap is normal, there always is some gap between plate and converter, you just have to pull converter forward a little to bolt it up, i dont know if 1/4" is too much or not, probably is fine, you dont want verter all the way into tranny pump anyways.
good luck
84LsxZ28
May 17, 2020 02:21 PM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
TexasMaro
Sep 15, 2015 06:50 PM
roysatikas
Sep 7, 2015 08:08 PM
