torque converter stall question
Old Oct 13, 2002 | 11:00 AM
fastvetteTPI84's Avatar
hey guys, I'v just replaced my converter in my 700r now as far a i knew the one i had was stock and if i was to stall it up ( the old foot brake hit the gas ) it would stall to 22, 2300 rpm now with the new one (a 2600 stall ) it will only stall to 1800 so whats the deal did i just buy a stock one or will it loosen up in the next few miles
thanks for any help
Old Oct 13, 2002 | 11:15 AM
4L60bliss's Avatar
No, it won't loosen up. What you see is what you get.
As for the 1800 RPM, thats probably correct for a 2600 stall. You more than likely won't see the full 2600 unless you have a trans brake or are launching hard with slicks.
As for the old "stock" converter doing 2200-2300, its unlikely. If it did, it was either busted internally or it was not "stock".
Old Oct 13, 2002 | 01:09 PM
hey thanks for the replay 4l60 ,
so let me ask you if i wanted to be able to foot brake it to 25-2600 rpm what stall would i need to get
Old Oct 13, 2002 | 01:11 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just watch your tach, when your cruising low speed in drive then nail it, I'll bet my left nut the convertor flashes to the advertised 2600. As far as the low end slippage I had the same problem with my Coan 2800, it would almost kill my motor when I put it in gear cause the cam needed a looser convertor, switched over to the TH350 and 3500 stall, much better 60' times and it drives pretty well on the street.
Old Oct 14, 2002 | 05:44 AM
EvilCartman's Avatar
Car: '82 Z28
My 2500 stalls at 2300 doing the foot on brake + gas deal :/
Old Oct 14, 2002 | 01:34 PM
well i got my answer , i called to where i got the converter (Tampa clutch and converter )and told him (tom ,who built it) my problem he said thats a problem with his converter and he would fix it and that it will do as i wish it to , now all i have to do is rip out the trans again ...gee wont that be fun !
thanks for all the help guys
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
