10 bolt vs 9 bolt
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
10 bolt vs 9 bolt
What is the difference between the 9-bolt borg-warner and the 10 bolt saginaw for thirdgens?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
They are 2 entire different types of rearends. The 9 bolt is much stronger than the 10 bolt, but the 10 bolt is cheaper than the 9 bolt. More information on the 9 bolt is at www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
there are guys in this board running 12's on stock 10 bolts..yea theyll live a fair share of abuse....but its likt russian roulette..ya just never know
10 bolt and 9 bolts are realitively the same in strength. You will hear good and bad about both. But the biggest difference about the two is that the 9 bolt has 'press-on' style axle bearings and no "C-Clip's". Other than that, they are VERY similar....
Car: 1980 Camaro Berlinetta
Engine: soon to be 383
Transmission: TH-350
Axle/Gears: GM 10 bolt 8.5 3.23
yeah but it always sounds "cooler" to say you have a 12 bolt.....thats what im lookin to put in my 80 Berlinetta
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
