Posi Rear how to identify by looking at it!
Old Oct 21, 2002 | 10:21 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Guys...I have a rear end in the garage....and I cant figure out if it has posi or not (partly because this is the first Time I have actually cracked one myself). By looking at it how can I tell if its got posi or not, well other than pulling the Axle code which is caked in crap....pics would be usefull too.
Thanks Dave
BTW I know its a 10 bolt with 3:42 out of an 87 GTA...dont know if that will help
Old Oct 21, 2002 | 10:35 PM
chacane67's Avatar
Pull the cover off and look..............
Old Oct 22, 2002 | 06:31 AM
ede's Avatar
ede
yep it's that easy look for the clutch pack after you pull the cover. lot of people will tell you to spin this and count that but it's not 100% for sure like pulling the cover.
Old Oct 22, 2002 | 06:36 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Well......I know I have to pull the cover off to tell (I am a newbee when it comes to rear ends but not that new....) What should I be looking for???
Old Oct 22, 2002 | 02:19 PM
chacane67's Avatar
Old Oct 23, 2002 | 03:06 PM
Marc 85Z28's Avatar
Re: Posi Rear how to identify by looking at it!
Unless the gears have been changed, that ratio is incorrect. The GTA's in 87 equipped with the 10 bolt got either 2.73, 3.08, or 3.23. 3.42 was not available.
Old Oct 23, 2002 | 04:31 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
look for something that looks like this:
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Yep, the gears were changed...figured that one out last night. Formerly a 3:23 axle
Old Oct 23, 2002 | 05:40 PM
Marc 85Z28's Avatar
Changed from a 3.23 to 3.42? That's odd. That's a good bit of money for that little extra gearing...
That picture curt86iroc put up is a posi diff. You should be able to notice the springs and clutches. The open unit only has 4 spider gears and a shaft in the diff.
Old Oct 23, 2002 | 07:52 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
ya thats what I thougth about about the change for something so small.....but the ring gear has it 3:42 stamped right on it and the pinion gear has X:42 on in I cant see the first nubmer all that well but I figure it is a 3:42....does this make sense?
And I am positive it does not have posi now.
Thanks Guys
Old Oct 23, 2002 | 08:07 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You sure it's stamped 3:42? Does it look like this? (sorry so big, too lazy to shrink it)
Thats 13:42 or 3.23 gears ( :== /, 42/13 = 3.23:1). The numbers represent the number of teeth. 13 on the pinion, 42 on the ring. The ratio is the ratio. Imagine that! Thats also why higher numerical gears can be weaker. Less teeth on the pinion make it smaller.
In case you're wondering, thats the POS eaton locker i have in my car right now. I swapped in a whole 84/85 axle, the eaton lockers were really used in the S10 line, but f-bodies got them in that period because of a shortage of auburns. And actually at first i thought they were 3.42s too, until i realized the colon, the worn out 1, and the logic of the situation.
Old Oct 23, 2002 | 08:51 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
That is exactly what I have right down to the p/n on the ring gear...So I guess they are not 3:42 and actually the 3:23 gears then, but I dont think mine is a posi...It does not look like that and I dont see any springs etc...all and all a good deal for 50 bucks canadian, even without posi I would say.
Old Oct 23, 2002 | 10:21 PM
chacane67's Avatar
Nice pictur Nic!
Looks like a Gov Lock, or Gov POP!!
Old Oct 24, 2002 | 02:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Mine popped too... go figure, even my V6 could kill those gov-locks.
Old Oct 24, 2002 | 04:43 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
how hard are used (decent posi units) to come by??
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
