Gear ratio Question.....Missing the RPO tag
Old Oct 21, 2002 | 10:40 PM
Keith27's Avatar
I just bought a project car, 88 GTA and the damn RPO tag is gone
I was wondering if there is a way of telling the ratio without taking off the cover??
And if not is it tagged on the gears??
Old Oct 22, 2002 | 06:30 AM
ede's Avatar
ede
take the cover off and you'll be 100% sure what you have. as old as it is the code or tag is pretty much meaningless anyway, someone could of swaped parts around.
Old Oct 22, 2002 | 08:40 AM
Keith27's Avatar
This is true, you know what Im doing this weekend.........
Old Oct 22, 2002 | 05:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If they're GM gears, it might be stamped on the ring gear. Mine was stamped 41:11, divide that and you get 3.7272727272 = 3.73. If not , just count teeth and divide!
Old Oct 22, 2002 | 11:07 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
If you don't want to take the diff cover off...
Non-Posi rear: Jack one wheel well off the ground and mark both the wheel and the driveshaft. Have someone slowly turn the wheel two full revolutions while counting the number of turns of the driveshaft.
Posi rear: Jack the rear of the car off the ground and mark both the wheel and the driveshaft. Have someone turn the wheel one full revolution while counting the number of turns of the driveshaft.
I've done this many times either at the wrecker or on a buddy's car. You'd be surprised how well you can eye up the ratio - especially when the 3rd gen ratios are well published. Just over 3 turns = 3.08, 2 and 3/4 turns = 2.73
Old Oct 22, 2002 | 11:14 PM
Keith27's Avatar
Thanks... That should get me close enough.
Peace
Old Oct 23, 2002 | 03:39 PM
Z28DJP1987's Avatar
Check your RPO codes if you have them, they will tell what came on the car stock.
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
