T5 Clutch Fluid Change
Old Oct 29, 2002 | 03:17 PM
Steve89GTA's Avatar
I need to bleed my clutch fluid cause it's old and damn dirty too. Can someone give me a quick rundown on how to do it? I've done brakes before...is it similar?
I don't remember seeing a bleeder screw on the clutch cylinder though..
Hmm
Any help is appreciated
Old Oct 29, 2002 | 11:21 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
well there is bleeder screw.
it is on slave cyl mounts on bellhousing if look at it you will see on upper side a tube comming from master cyl and right next to it (motor side) there is your bleeder screw if you did not find it let me know so I'll send you a pic of it
good luck
Old Oct 29, 2002 | 11:24 PM
Steve89GTA's Avatar
Cool, so it's right next to where the tube connects to the cyclinder that goes up to the fill cap under the hood?
Thanks for the info man!
Old Oct 29, 2002 | 11:27 PM
Steve89GTA's Avatar
Just a quick question. is the bleeder screw like the ones from brake calipers where I can fit a hose over it and loosen? I remember hearing from someone on here that it may be just a regular screw.
If it's just a regular screw, how do you bleed it without letting air in? Do most guys replace it with a bleeder similar to those on calipers? I wonder if they are the same size..
Thanks for the help!
Old Oct 30, 2002 | 11:19 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
HERE YOU GO
1 CHECK THE ENTIRE HYDRAULIC CIRCUIT TO MAKE SURE THER IS NO LEAKS
2 FILL THE MASTER CYL WITH DOT3 FLUID (NENT TO BREAK BOOSTER)
3 LOOSEN THE BLEEDER SCREW AT THE SLAVE CYL APPROXIMATELY ONE-HALF TURN
4 FULLY DEPRESS THE CLUTCH PEDAL THENMOVE THE PEDAL THROUGH THREE QUICK AND SHORT STROKES
5 RELEASE THE PEDAL RAPIDLY
6 KEEP DOING IT 'TILL NO AIR EVIDENT IN THE FLUID LEAVING THE BLEEDER SCREW
7 CLOSE THE BLEEDERSCREW IMMEDIATELY AFTER THE LAST DOWNWARD MOVEMENT OF THE PEDAL
Old Oct 31, 2002 | 07:52 AM
Steve89GTA's Avatar
When releasing the pedal, won't the system suck air in?
Is the bleeder screw similar to a caliper bleeder where I can attach a tube? .. or is it a simple screw?
Thanks for your help!
Old Oct 31, 2002 | 11:56 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
the systemwill not suck air if you releasing the pedal rapidly
and the screw is simple you need an allen wrench and I'll send a pic of it today if I got chance.
Old Oct 31, 2002 | 12:02 PM
Steve89GTA's Avatar
Thanks man...so I keep filling the top as I pump the pedal - and release the pedal quickly.
When closing the screw, can I hold the pedal down all the way with something and then close the screw..or does it have to be done when the pedal is being pushed to the floor (in this case, i would need someone to assist.)
Thanks again for the help.
maroe624
Apr 16, 2017 08:29 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Thornburg
Aug 25, 2015 01:46 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
