how do i mount the clutch master cylinder?
Old Nov 1, 2002 | 02:49 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
anyone know the part number for the u bolt that holds the clutch master cylinder to the firewall, and/or the part number for whatever holds the clutch slave cylinder reservoir?
thanks,
Rick
PS- this is for a T56.
anyone have a part number for the master/slave cylinder? or reservoir?
Old Nov 1, 2002 | 06:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It should use a bracket that bolts to the brake booster/brake master cylinder.
Old Nov 2, 2002 | 03:16 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
There's the bracket that is part of the pedal assembly, it connects to the brake boosterand clutch master cyl, but I dont think that's what he's talking about.
Rick, you're probably going to have to get the u-bolt and reservoir from the dealer. They should be able to find the part number for you. As for mounting the reservoir, I just used two of those plastic body clip things (looks like a big plastic thumbtack), and popped them through two holes I'd drilled through the firewall.
Old Nov 2, 2002 | 11:06 AM
ctandc's Avatar
GM can get you the pt#. The U-bolt faces in to the firewall, and this where the two pedal braces attach as well.
As for the resovoir, it's normally held on with a small clamp that slips under one of the brake master cylinder bolts where it bolts to the brake booster.
HTH
Old Nov 2, 2002 | 08:38 PM
Car: 90 Camaro RS
Engine: 305 TBI
Thanks guys!
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
