700R4 in an 82 T/A, crossmember Q's
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I am wondering if a crossmember from an 88 Formula will fit a 82 Trans Am. The 82 has a 200C, so I was thinking about switching trannys. I am wondering if any holes will need to be drilled, or any other modifications.
No, the crossmember from the 88 formula will not fit your 82 trans am. The hole locations on the frame are different, it would probably be easier to modify your current crossmember. I am doing the same swap this week, I ordered the crossmember from Spohn its about $100.
Car: 1989 C4
Axle/Gears: 307
Yep it doesent fit, I made the mistake of cleaning & painting the one I got from the junk yard $20 bucks down the tube.
I used the old 200c crossmember. I slid the crossmember back and with a little enlarging of the front two holes was able to to mount it in the back nuts, two quick spot welds and it was done.
Its held up for a year so no complaints. The 700R4 is well worth the effort.
Edit. BTW the 200c tq arm doesent fit right either, your going to either have to get a 700r4 tq arm or chop about 2 inches off the 200c one so you can clear the sppedometer housing.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
