Rear End Help
Old Nov 6, 2002 | 11:26 PM
92RSMuscle's Avatar
Rear End Help
some quick questions:
what size rears came with a posi? both camaro and firebird
did 2.77 come with a posi?
also, what size rear does a 4wd blazer have...like made in 85
Old Nov 7, 2002 | 12:59 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Rear End Help
More than likely it has the posi because that's the Borg Warner 9 bolt. Those usually came with posi. The only sure fire way to tell...... well there are actually two ways to tell. 1) RPO code. If it's a G80 you got posi. 2) Lift rear end off the groung (both tires) and spin one wheel. If the opposite wheel spins the other way, you don't have posi. If it spins the same way, you do.
If you mean numerically gears....... you need either the RPO code or the axle code on the axle housing. If you mean diameter, it's a 7.5".
AJ
Old Nov 7, 2002 | 08:49 AM
92RSMuscle's Avatar
thanks
just to get my facts straight, no 2.77 came stock with a posi right?
whats the formula to find out gear ratio?
Old Nov 7, 2002 | 11:14 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
99+% of all 2.77 ratio borg warner 9 bolt 7.75 rearends were posi units.
Miles
Diff Solutions
www.9bolt.com
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
