Rear end parts broken?
On my car i'm putting a posi rear end under it from another camaro (basicly just swapping) andthe bar that keeps the rear end from swaying is bend all out of whack and the passenger side bar (the one that goes from the body of the car to the rear end looks kinda like a bone) and some of the bolts were ben't and the old rear end was bent a little bit.
Any idea of where to find this sway bar type thing and the mount?
Car: 85 IROC
Engine: LB9
sounds like you are talking about the rear sway bar and the Lower Control Arm....you can get an LCA off of any 3rd gen. There are a variety of sway bars, not all 3rdgens had rear sways and the ones that did had different thicknesses, any rear sway off of a 3rd gen will bolt up though. You can get these parts at a junkyard or contact the sponsors above, look on ebay or go aftermarket and get better than stock. No matter witch way you go, new bushings and sway bar end links are a must do.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If you have trouble finding these parts, let me know. I just picked up a spare rear end with both lower control arms and the panhard bar. (Long bar that goes side to side) Also have a stock 18mm sway bar with all the mounts I don't need.
Dan
Dan
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
