Well - That explains why it's grinding...
Old Nov 21, 2002 | 01:38 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm using the wrong tranny oil!! I called to order a rebuild kit from Gearzone.com, I called, and the guy on the other end (Paul), was very helpful. I explained that 2nd gear grinds sometime, and he was saying that most boxes fail due to lack of lube.
I then mentioned I believe that's what happened to mine in it's past life, because I had to replace the input shaft bearing. But now I keep it topped off with 80W90 like my Haynes manual recommended. He said "You're running the wrong lube". I was amazed because I even had a shop check the lube on it, and they said nothing about having the wrong lube. He even asked me if I wanted to hold off on my order until until I try Mobil-1 ATF synthetic like he recommended.
Even if it doesn't work with the new lube, I appreciate a shop that was more willing to help a person rather than just take thier money..
I was impressed, and I highly recommend them!
Old Nov 22, 2002 | 12:50 PM
MdFormula350's Avatar
glad you got things straightened up!
Old Nov 22, 2002 | 01:15 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks Md, I don't know yet whether the problem is solved yet, because I'm stuck working and don't have the time to try it out. I will this weekend though.
I anticipate it will make a HUGE difference. With 80W90 in there, it grinds when going into 2nd - but only when the car is relatively cold. After about 1/2 hour it starts shifting smoother and smoother.
With my luck though, it'll most likely leak somewhere when I use the ATF.
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Cacike
Aug 27, 2015 05:10 PM
