differents?
Old Nov 21, 2002 | 03:21 PM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
differents?
Can any one tell whats the differents between v-6 trany and a v-8 trany. i have a 88 camaro that i would like to put a manual trany in it but right now it has a 700r4. i see a lot of v-6 camaro around here with manual.
thanks
Old Nov 21, 2002 | 04:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The gear ratios are different; the 6-cyl trans has much wider ratios than the V8, so you get the same effect as the 700's 1st-2nd shift, except at every shift. And, the input shaft is smaller and has different splines, so it doesn't fit a V8 clutch.
Old Nov 21, 2002 | 06:44 PM
4L60bliss's Avatar
You will also need to find a V8 bellhousing.
Old Nov 22, 2002 | 12:52 PM
MdFormula350's Avatar
what manual tranny are you going to put in?
Old Nov 23, 2002 | 10:56 AM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
right at the time i dont have the money to put the tranny i want in it (richmond 6-speed) so i was thinking maybe what i can find in a junk camaro and have it rebuild. unless you guys know a of better way to do it pleace tell. i want a manual in there.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
