How do you remove the shifter arm?
Old Nov 26, 2002 | 12:42 PM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
I'm dropping my T5 out of the car too do some clutch work and i can not figure out how to remove the shifter arm. How does this damn thing come off?
Old Nov 26, 2002 | 01:14 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
You have to un bolt the entire shifter from the trans. Pull the shifter boot and whatever esle may be in the way, and the take out the 4 bolts that hold the shifter to the trans. Then it just pulls up and off. Be sure not to loose the little plastic bushing the shifter ball goes into.
On my car I have to pull the console up to get at the shifter boot bolts. It's a pain, but no other way to do it.
Old Nov 28, 2002 | 01:33 PM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
this sucks!!! Why couldn't they have made it where the arm can come off!!
Old Nov 28, 2002 | 01:46 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I've seen guys remove the shifter from underneath so they didn't have to pull the console. Just get the right 13mm wrench and it can be done.
Now that i think about it, I've only seen it done on 4th gens. It should be the same though.......
BewleyBizzIROC
Feb 3, 2020 09:52 AM
deracer
Apr 11, 2016 12:04 AM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
