Tranny mount replacement Q's???
Old Dec 2, 2002 | 05:03 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I bought an energy suspension poly. trans. mount and went to put it on the car. I put the mount in and noticed that the only bolt they supply in the kit didn't fit into the mount, where it holds the crossemember up. I could only get this bolt in a few threads before it would stop going in, and the bolt on the old mount looks like it's part of the mount and not supposed to come out, there's no head or anything. My question is what bolt do you use to connect the crossmember to the mount? I put the stock one back in for now, but I'd like some help with fixing this. Thanks.
Old Dec 4, 2002 | 04:33 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Any help here with how to bolt the crossmember to the mount??
Old Dec 4, 2002 | 08:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
I think I had this same problem twice with the ES mount. The bolt they supply wouldnt pass through the crossmember. I ended up drilling the hole in the crossmemebr out some to get it to fit. The OEM mount has a bolt that is bonded to the mount and uses a nut to hold it together. it all esles fails then take the mount to a local hardware store and get the correct bolt. make sure it is a grade 8 bolt
Old Dec 4, 2002 | 10:48 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...nnymount.shtml
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
