park in now reversed why ???
Old Dec 6, 2002 | 12:48 PM
falconfires's Avatar
Park is now reverse ?
Ok what is wrong with my car. when i shift into park my 85 trans am goes in reverse. It feels loose like the teeth or whatever in the gears dont hold . I already spent 2,200 fixing brakes, something with the idle and tune ups,some computer chip and I alot more. I just changed the transmission fluid 2 months ago. how much will it cost to fix this problem now ?
Old Dec 6, 2002 | 07:22 PM
4L60bliss's Avatar
Check to see that the two bolts that bolt the shift linkage bracket to the tranny didn't come loose.
Old Dec 7, 2002 | 02:56 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
it could be just a simple adjustment
Old Dec 7, 2002 | 03:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Park is now reverse ?
holy damn! id have gotten rid of the car, screw that!
brkes must be made of platinum ?
sounds like cable needs adjusted definitely
Old Dec 8, 2002 | 12:56 PM
you misunderstood
no i spent 2,200 fixing the engine and some electric stuff. like horn and trunk button and lights. I had to get whole new brakes drums and pads costing $ 220. Just curious i went around looking for tires and i found the cheapest at $128 each is that really the cheapest other then used ones ???
Old Dec 8, 2002 | 01:57 PM
4L60bliss's Avatar
Go to Tirerack.com. I bought 4 Kumho 712, 255/50/16, "Z" rated tires for like $88 each. To have all 4 shipped to my front door, was about $395.
RedLeader289
May 28, 2019 01:47 PM
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
