Bad Ujoint question
Old Dec 10, 2002 | 08:40 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
Bad Ujoint question
my front ujoint is bad and sounds horrible when you give the car some power.. my question is
tomorrow i need the car for like 8 miles, if i go REAL easy on the car and not go over 40mph is it safe to drive??
from a dead stop if you give it about half throttle it will CLUNK and if you floor it in 1st to 2nd gear shift it will squeel..
so i'm guessing if i go extremely easy, it will take me the 8 miles i need to go??
Old Dec 10, 2002 | 08:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably...
On the other hand, have you ever seen what happens when the fron of the drive shaft drops and hits the pavement? It basically makes the rear end of the car do a pole vault. I had (note I said had) a friend riding in the back seat of a car when that happened....
Very risky behavior. Russian Roulette for all proactical purposes. Is a chance on your life worth 8 miles?
Old Dec 10, 2002 | 09:05 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
hmmmm how often does this happen?? i'll only be doing 40mph max i would hope thats not enough for anything bad to happen..
but now i'm a little afraid
Old Dec 10, 2002 | 09:28 PM
383 rocket bird's Avatar
The work truck I drove all summer had a banging and squeaking u joint that never broke. On the other hand recall all the times that we have said it'll be fine till I... and then lived to regret it. That wasn't my truck and if it was I NEVER would have driven it. Can't you borrow a car or have a friend take you if it is only 8 miles?
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
