Torque Convertor Help
Old Dec 11, 2002 | 01:42 PM
camaro_1983_383's Avatar
heres my deal, i need a torque convertor and im a little unsure of what i need. here are some specs on my engine, if anyone educated in this subject could give me some recommendations. also, do i have to pull the engine or tranny to change it?
383 with currently stock heads (will be changing soon), Crower Hydraulic cam 112* .462"/.470" (crower recommends going 500-700 over stock TC), forged crank and rods, KB hyper. 10:1, Street avenger 670, Torker intake (will also be changed to perf. rpm probably). I have a TH-400 which i was told was non-lockup by a member here. i have a dual bolt pattern flywheel. any other info needed?
Old Dec 12, 2002 | 01:25 PM
nobody????????????
Old Dec 12, 2002 | 05:18 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
What is your rear end gear?
What do you want to do with the car? Drive it or race it or both?
Old Dec 12, 2002 | 05:27 PM
Pro Built Automatics's Avatar
I need to know the duration of the camshaft .050 lift?, the rear end gear ratio?, type of driving you do?, etc.
Old Dec 16, 2002 | 01:06 PM
Thanks for posting. the rear is a 3.73, but it doesnt have posi, i can smoke my pass. side tire all day long, but nothing from driver side, but anyways, the cam duration at .050 is 218*/226*. the adv duration is 278*/284*.
I mainly use the car for street driving, i live 15 miles out of a small town so i see alot of highway. but once i get into town i tend to get on the throttle a little bit. the car hasent seen the strip yet, but it will probly once a month this spring. i will be moving to pheonix this summer, so i will see alot of city driving and i like to launch off of the light, but i dont want 6 m.p.g. either. Thankyou for the replies. any other info needed?
Old Dec 18, 2002 | 11:09 PM
I would go with the A.C.T. 9.5" lockup with apx. 2,400-2,500 rpm stall with your combination. This will keep the gas mileage the same on the freeway, and with just a little loss around town. They go for $565.00 and come with a one year warranty and a free stall change if necessary. Let me know?
Old Dec 19, 2002 | 04:23 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Dana he said he had a TH400 non lockup.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
