can't figure this out
Old Dec 15, 2002 | 11:29 PM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
I posted this on the TPI board first,but may be tranny instead.The car ildes at 500rpms normally,but when I go WOT and the overdrive kicks in and come to a stop it ildes at 1000rpms until I tap the gas a little,then drops back to 500rpms,I tried some carb cleaner on the throttle linkage,no change.any ideas?Thanks
Old Dec 16, 2002 | 06:41 PM
4L60bliss's Avatar
Could be a weak throttle return spring... I know a guy that had problems identical to yours after installing a 383. We were wondering if the engine was actually sucking the throttle blades open. We couldn't find anything binding at all, so we put a little "helper" spring on it and have not had a problem.
Old Dec 17, 2002 | 01:34 AM
JohnS's Avatar
Engine: 3.5 V6
Thanks,I just wanted to make sure it wasn't tranny related,guess I'll clean the throttle out and change that spring.
Old Dec 17, 2002 | 08:10 PM
BOTTLEDZ28's Avatar
Transmission: A4
what many guys do is clean out there TB's with a solvent cleaner and never lubricate the throtle shaft afterwards. tryputting some light grease on both side of the shaft and see what happens.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
