98+ T56 different than 94-97?
Old Dec 14, 2002 | 09:34 PM
MILT's Avatar
Just curious--all articles talk about the 93-97 t56s as "direct bolt-ins." Did they change designs in 98, or will they work as a swap in as well?
MILT
Old Dec 14, 2002 | 10:02 PM
draino
Guest
Posts: n/a
Yes they are different. The bellhousing, clutch, and input shaft were changed to accomodate the LS1. Also, they are not as strong as the older ones that were used in LT1 F-bodies. I think that has to do with Borg-Warner changing to Tremec. I am told that you can change the parts and use a newer one, but I'd use an older one instead since you get the better sincro's and I believe the blocker rings were better quality. From experience my 96 T56 feels alot smoother than my 01 did.
Old Dec 17, 2002 | 08:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
the clutch is engaged differnet too. the LS1 cars use a different method of engaging he clutch. i dont think they use a fork
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
