posi...easy way of getting it?
Old Dec 16, 2002 | 09:21 AM
91BlkRS's Avatar
some kid in my automotives class was telling me the other day while we were replacing the clutch in an '89 RS that all you have to do to get posi is to get a pin inside the axle to stay down or pushed in or something like that. we started this discussion because the RS had posi, but i can understand that because she had also gotten the dual snorkel k&n, so she's been doing some work on her RS.
Old Dec 16, 2002 | 11:11 AM
ede's Avatar
ede
don't believe everything someone tells you
Old Dec 16, 2002 | 01:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
What I think they are trying to get at is a mini spool that will lock the rear axles togather. Not for street use unless tou can take corners reeeeaaaly wide. Of cousre you could always break out the welder and weld the spider togather. :P Dont weld the spiders togather!
