Rearend Question Please Help
Old Dec 22, 2002 | 11:15 AM
92camaro's Avatar
I am about to purchase a Zexel take out posi unti form SLP and a Richmond 4.10 gear for the stage 3 carrier. What else do I need to make the swap? I have a 1992 camaro RS with a built 350 and auto trans and it is begging for the 4.10 gears. I have a 3.08 right know. Thanks for the help.
Old Dec 22, 2002 | 11:29 AM
4L60bliss's Avatar
Well, your obviously going to need a 4.10 Ring and Pinion set, plus you'll have to get the shim kit to install it. I would reccomend you get the kit that comes w/ bearings as well. Now is not the time to cut corners. I'd also get an aluminum girdle cover for the rear. It helps beef things up a bit.
Old Dec 22, 2002 | 12:06 PM
ede's Avatar
ede
i'd weld the axle tubes to the center section too.
Old Dec 23, 2002 | 10:41 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...nguprear.shtml
http://www.ws6transam.org/10bolt.html
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
