Rearend advice
Old Dec 22, 2002 | 09:42 PM
Reddragon91's Avatar
Car: 1991 RS
Engine: 87' 350 TPI
Transmission: 700
Rearend advice
I need some help. I have a 91 RS that I swapped in an '87 350 tpi with a new cam. I plan on getting some 2.02 heads in a few months. Ok, here's my question, do I just switch out my gears or do I find a new rearend altogether from a Z or IROC. Also, what gears should i get, 3.42 or 3.73. Thanks guys.
Old Dec 23, 2002 | 06:03 AM
ede's Avatar
ede
either will work, lot will depend on your ability to swap gears, or just the rear. ratio depends on what you want it to do, or what you want to do with it. little more info would help.
Old Dec 23, 2002 | 10:30 PM
MdFormula350's Avatar
well if you have drums brakes, no posi, and not a good ratio i would think into getting another rear with disk brakes at least and work from their. do you want a 9 bolt bw or a 10 bolt rear end..
UltRoadWarrior9
Apr 28, 2020 10:39 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
