manual valve body
Old Dec 24, 2002 | 09:34 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
manual valve body
Can you use a manual valve body on the street or is it a strip only item? If you can't why not? I have a shift kit now and it shifts very hard so im not looking for a firmer shift id just like to shift my own gears without conveting to a stick and I hear its bad to manually shift it without a manual valve body.
Thanks.
Old Dec 24, 2002 | 09:39 PM
4L60bliss's Avatar
Manually shifting an auto is not bad for it, you just don't have full control. If you kick the shifter from first to second, you still have to wait for governer pressure to overcome spring force and TV pressure before it will shift. On a manual valvebody, as soon as you put the shifter in 2nd, it WILL be in second. Same goes for taking off from a stop. On a regular auto, if you put it in Overdrive, it will start in 1st and shift through the gears untill finally getting into overdrive. However, on a manual valvebody, if you put it in overdrive, it WILL start out in 4th gear. You'll have to manually put it down into first every time.
Old Dec 24, 2002 | 11:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You really have to know what you're doing if you want to use a manual valve body on the street as mentioned above. It's very easy to forget it in D or OD and drive around like that. The clutches will get burnt up in no time.
A manual valve body usually also eliminates engine braking in all but high gear. This means if you are in any of the lower gears and you lift off the gas pedel, the tranny will act like it's in neutral.
For street use, a shift kit is the best choice. You can still manually shift through the gears if you want but if you put it into D or OD the tranny will automatically shift through the gears like normal.
Old Dec 25, 2002 | 03:38 AM
Pro Built Automatics's Avatar
Trans-Go offers the "full manual" setup in the Performance Shift kit as an option. I have only seen one person in the past several years use it. In my case I have never setup a full manual 700R4. Personally, I do not recommend it on a 700R4.
Old Dec 25, 2002 | 07:47 AM
Mark W. Winning's Avatar
Both of my automatics, a glide and a t-350, are full manual valve bodies. IMHO they are not a problem to use on the street. Yes, you have to upshift and downshift it, but to me that is half the fun of driving. Again, though, these are not 700's.
Old Dec 25, 2002 | 06:20 PM
As you said, they are not 700R4's. If you insist on this, go thru the transmission first, and install "all" the HD upgrades, if you want it to last.
X
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
