Piolit Shaft Bushing
Old Dec 26, 2002 | 08:47 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Pilot Shaft Bushing
I was told that NAPA carrys a roller piolit shaft bushing replacement. I called my local napa and no luck. The person that informed me is un-avaliable for about a month.
Does anyone know the part # for this, or can you call your local napa for me and ask for me since mine seems to be lost.
Its for a 60deg v6 engine.
Say 85-91 camaro 2.8/3.1
or 93-95 camaro 3.4l
Thank you!!!
Old Dec 26, 2002 | 09:31 AM
ede's Avatar
ede
call another chain or gm parts. to me it isn't that big a deal, i've run or used bronze in lot of cars or trucks with no problems, needle bearings aren't always to be had. measure the hole, the bore, and length and give BDI a call. they should be able to hook you up.
Old Dec 26, 2002 | 11:23 AM
Dale's Avatar
Engine: 350 S-TPI
Whos BDI??
And are you saying its not worth it? Just get the reg one?
Old Dec 26, 2002 | 01:33 PM
ede's Avatar
ede
bearing distributors inc., use to be bearings inc.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
