transmission problem
Old Dec 31, 2002 | 06:58 PM
hurricanerugger's Avatar
everytime I shift into either Reverse or Drive my car jolts very badly. I never have any other problems with the trany other than that. what is this from. And what is the best why to remedy this. The last time it did this, it moved my car a whole foot on the road.
Old Dec 31, 2002 | 07:42 PM
4L60bliss's Avatar
What year is the tranny? Have you ever adjusted the TV Cable? Does it shift normal?
Old Dec 31, 2002 | 09:02 PM
wha'ts the TV cable? it seems to shift normally when I'm moving, just when I initially shift to reverse or drive.
Old Dec 31, 2002 | 09:44 PM
4L60bliss's Avatar
If you have a TPI, it will be right HERE:
If you have something else, the cable will still look similar. Do a search on here about adjusting the cable. Lots of people have had luck w/ Transfixleo's method.
Old Jan 1, 2003 | 09:37 AM
thanks, I'll try that.
Old Jan 1, 2003 | 09:40 AM
how much should I adjust it? just some, and check the tranny each time until it's fixed?
Old Jan 1, 2003 | 09:42 AM
I'm trying to find TV cable in my Haynes manual, but it's not there, is there another name for it?
Old Jan 1, 2003 | 09:43 AM
ok, I'm not retarded anymore, I found it.
Old Jan 1, 2003 | 09:44 AM
4L60bliss's Avatar
How much do you adjust it? There really is only one adjustment, which if you go by the procedure, will put MAX Throttle Valve at Wide Open Throttle.
You should only have to do it once. If that doesn't solve the problem, then it might not be the problem. Its just a starting point. Something easy and common that you can rule out.
Old Jan 1, 2003 | 09:48 AM
ok, I found it, and am looking at it, but how do I adjust it?
Old Jan 1, 2003 | 09:55 AM
it worked, thanks.
Old Jan 6, 2003 | 08:26 AM
Chupakabra-King's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
ummmmmmmm , I got a question , what if the TV cable is missing ? mine is , and it jolts like that too , also , it acts like it slips when it is changing gears , but it doesnt slip once its in gear . I serviced the tranny and found no metal shavings . Could the problem be that missing TV cable ? someone told me it sounded like the converter was going bad and not locking up properly . does that sound feasible ? Thanks for the info guys !
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
