TH-700R4 Question
Old Jan 13, 2003 | 02:26 PM
Chupakabra-King's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
TH-700R4 Question
Ok guys , heres one for ya . When my car changes gears , it acts like it slips out of the gear that it is in and then goes to the next gear. It does it in all 4 gears , but once its in gear , its in gear and you can put the pedal to the metal . Someone told me it could be the convertor and im thinkin it probably needs to be rebuilt . When i changed the fluid after i purchased it , the fluid was noticably neglected , dark red , light brown looking . no metal particles or chunks in the pan , only friction material from the clutches is all I could see . I re-adjusted the TV cable but it didnt stop this from happening . Does it sound wore out to you guys ?? Any suggestions as to what could cause this to happen and prevent me from spending a small fortune would be most appreciated .
Old Jan 14, 2003 | 04:56 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
drop the pan and change the filter.......what ya got to lose? Might help might not...
Old Jan 15, 2003 | 04:15 PM
Engine: 305 TBI
Axle/Gears: 3.08
I changed the tranny fluid and filter as soon as i got the car home . I didnt notice this when i test drove the car . Cmon guys , anyone seen this problem b4 ? As always , any and all help is very much appreciated by me and my T/A
Old Jan 16, 2003 | 11:55 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
that is called rpm flare, it is caused fromseals leaking inside the trans, you most likely need a basic overhaul, but try doing a fliud/filter change and use something like transmedic or similar first(only going to cost total $20-30)
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
