upgrade existing 5spd
Old Jan 13, 2003 | 02:38 PM
Z28Clone's Avatar
I am installing a 350 in my RS. It has a stock 5spd. Can I beef up my 5spd instead of going through the pain of replacing it with a 6spd? Ive read what I need to do about putting in the 6spd, too painful. What parts do I need to upgrade inside the 5spd instead?
Old Jan 13, 2003 | 08:44 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
either a new WC-T5 for ~1200 or
http://www.fortesparts.com/tremec/tr3550-2.html
Old Jan 13, 2003 | 11:29 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I put a 300 HP 350 in front of my stock T5 in Dec 2001.
It lasted about a year (I drive pretty hard)
Put a Tremec TKO in two weeks ago and am very happy.
(from Fortes)
Don't waste any money on beefing a T5, it won't be any stronger than stock and they're only rated at about 295 ft/lbs.
(that's why they never offered them behind a 350)
In the end, you'll be much happier with a Tremec (3550 or TKO) or T56. I didn't feel like I needed the sixth gear ( I'm running 3.73's in the rear) and my friend at the Pontiac dealership sees a lot of T56's with wasted gears (third especially) behind stock TA LS-1's.
If you don't bang gears and dump the clutch on sticky tires, the T5 will last...........a while.
My 2 Cents.
-Rich-
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Zell1luk
Sep 29, 2015 10:36 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
